YoshimuraXPO
#1 Posted : Monday, December 10, 2012 1:20:26 PM(UTC)
YoshimuraXPO
My kitchen was flooded in Hurricane Sandy. Before throwing out everything, I am trying the appliances one by one to see if they can be salvaged.
The refrigerator, Kitchenaid KBRS19KTless than 4 years old, was flooded and toppled over by the flood waters. After standing it upright for over 5 weeks now, cleaning it and switching it on, the compressor, condensor fan, evaporator fan, lights, and the temperature controls work, but there is no cooling in the frig or freezer. The compressor runs till it is too hot to touch, but no frost on the coils in the bottom freezer even after 4 hours of continuous running.
I am wondering if this is not a major sealed system issue and anything else can be done.
Thanks very much for your help!!
Simon / APP Team
#2 Posted : Monday, December 10, 2012 2:24:50 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Make sure that the compressor is running. Do you fill vibration when you put hand on it?
If you do than most likely it's the sealed system problem.
Simon.
#3 Posted : Monday, December 10, 2012 3:08:01 PM(UTC)
If the fridg had power when it fell over, the compressor ran out of oil and burned up.
YoshimuraXPO
#4 Posted : Monday, December 10, 2012 7:40:56 PM(UTC)
YoshimuraXPO
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
I checked today, it's not vibrating. is that a start/ relay switch problem?
YoshimuraXPO
#5 Posted : Monday, December 10, 2012 7:42:42 PM(UTC)
YoshimuraXPO
The frig was unplugged and the main breakers were off before the storm surge. Also power went out before the water came in, so it wasn't running.
#6 Posted : Tuesday, December 11, 2012 1:00:23 AM(UTC)
Replace the start device available on this parts site.
YoshimuraXPO
#7 Posted : Tuesday, December 11, 2012 10:51:36 AM(UTC)
YoshimuraXPO
And then again, this morning, the compressor appeared to be running and vibrating (I felt it again) and still no cooling. Still a start device issue? (I'm planning to replace it anyways and see, since a $50 device could save a much more expensive frig.)
When I turned off power to the unit after about 15 mins, there was a prolonged hissing sound and a slight burning smell. Is that the oil in the compressor?
Someone also suggested trying to heat the coils with a heat gun or something to 'burp' the refrigerant in case there was a bubble somewhere.
Any further thoughts?
Simon / APP Team
#8 Posted : Tuesday, December 11, 2012 2:54:29 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Try to replace the start components, but it's sound like the sealed system.You can call the service company and find how much is to fix the restriction.
Simon.
#9 Posted : Tuesday, December 11, 2012 3:33:19 PM(UTC)
If the compressor is vibrating and hot, but you have no cooling, you either have a bad compressor or a system refrigerant leak.
Guest (4)
