nola mike
#1 Posted : Sunday, December 2, 2012 3:28:58 PM(UTC)
nola mike
I keep blowing the thermal cut out on the above dryer. Not sure why. No outlet obstructions. The odd thing (I think) is that the hi limit thermostat is good--this should protect the cut out, correct? I'm wondering if something is wired wrong. I didn't pay a whole lot of attention to which red wire went where when I replaced it the first time :o
My understanding is that when the temp > 250, the Tstat opens, cutting power to the coil. In the case of a Tstat malfunction, the thermal cut out is there for backup. So if the tstat is OK and opens, why would I be burning out the cut outs?
#2 Posted : Monday, December 3, 2012 12:35:03 AM(UTC)
Parts for Whirlpool LTE6234DQ2 Washer Dryer Combo - AppliancePartsPros.com
See the attachment for the wiring diagram. It should help you check the wiring to be sure it is OK.
Below is my usual blub on your type of problem.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
File Attachment(s):
LTE6234.pdf (297kb) downloaded 10 time(s).
nola mike
#3 Posted : Sunday, December 9, 2012 1:50:25 PM(UTC)
nola mike
Yeah, I'm not sure why the hi limit t-stat didn't trip before the cutoff--like I said, it does cycle when heat is applied. Anyway, I put the new kit in. Thanks for the wiring diagram. I had thought that all of the wires/tstats were in series and it didn't matter where they went. Looks like that isn't the case though, and I guess I could have wired it to where the hi limit tstat wouldn't have shut the heater, but the cutoff would have. I verified that the unit is now cycling appropriately, with an outlet temp of 125-168' (and I can hear the cycling tstat clicking). No shorts in the heater. We'll see if that fixes it. Thanks for the help.
#4 Posted : Monday, December 10, 2012 11:01:34 AM(UTC)
You are welcome.
I will keep my fingers crossed.
nola mike
#5 Posted : Tuesday, December 18, 2012 3:16:45 PM(UTC)
nola mike
Well, that didn't last long. Same problem. I don't understand why when I test it, the cycling t-stat seems to be working. Also I don't see why the cut off would keep blowing when the hi limit tstat also seems to be working. I had some semi-rigid duct in there that was slightly squished, but I don't think enough to limit airflow significantly. Anyway, I replaced it. Total vent run is only about 2-3 feet from the wall, and the dryer is right next to it. Maybe 6 feet total. I seem to be getting a lot of air out the back of the dryer, doesn't seem like any obstructions present. I forgot to check the seals for an air leak, but with the cycling tstat working and the unit cycling, everything appears to be working like it should...
#6 Posted : Wednesday, December 19, 2012 1:53:27 AM(UTC)
First check your wiring.
Next check for a grounded element. The element can short out in many ways and cause problems with different symptoms.
If all is OK as per my earlier post then replace the main thermostat as it may be sticking closed every once in a while. This is a bit of a long shot.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Nothandy_ri
#7 Posted : Monday, December 24, 2012 11:29:44 AM(UTC)
Nothandy_ri
Cutoff replaced and blew again
Have checked meter readings
Check the heating coil :)Yes it is between 10 to 12 ohms.
Checked from each side of the coil to the case/frame :)yes both show infinite ohms (open).
The hi-limit reads 0.6 to 1.0 ohms
Note: my digital meter shows a static 1 (w/o decimals) for infinity
Whirlpool Model LER4634EQ0
#8 Posted : Wednesday, December 26, 2012 1:51:25 AM(UTC)
Nothandy_ri
I would be best if you start your own post using Post New Topic.
This type of problem can be model specific.
I would follow the recommendations I made earlier if your unit is a close match.
Also I will be unavailable for a few dats as I am off to the cabin to play in the snow.
Nothandy_ri
#9 Posted : Sunday, December 30, 2012 2:08:41 PM(UTC)
Nothandy_ri
Denman Ok
Reposted as New Post on Dec 28 as "Thermal Cut-Off Blew after being replaced"
