gbumaga
#1 Posted : Tuesday, December 4, 2007 2:29:30 PM(UTC)
gbumaga
One of the burners on my Thermador cook top is sparking when turned on but gas does not flow. I understand, after finding some information on the web, that most likely I need to replace the potentiometer switch. Does anyone has instructions on how to get to it? I suspect that first I need to remove the cover, but not sure how to do it. Please help!
Many thanks in advance,
George
#2 Posted : Wednesday, December 5, 2007 11:46:34 AM(UTC)
Which burner is not working properly? Only two of them have the potentiometers.
Also I need you to post the serial number of the unit.
- Here are the break down diagrams for the Thermador range Model SGCS365RS
gbumaga
#3 Posted : Wednesday, December 5, 2007 7:04:58 PM(UTC)
gbumaga
Hi Gene.
Thank you very much for your answer. The serial number is 99050965. The burner which does not work is the front right one (#14 on the diagram).
Thanks,
George.
#4 Posted : Wednesday, December 5, 2007 10:19:37 PM(UTC)
The problem could cause by one of two parts: the gas burner valve or the knob cracked inside.
The gas burner valve is no longer available.
- The part number for the knob AP2832336
gbumaga
#5 Posted : Thursday, December 6, 2007 10:50:35 AM(UTC)
gbumaga
Thanks Gene! I will try to the knob from other burner to see if this is the problem. I hope that it's so easy... In case it's not, what are my options if new gas burner valve is not available? Does it mean that I need to forget about this burner and just live with it?
Thanks again,
George
#6 Posted : Thursday, December 6, 2007 10:57:29 AM(UTC)
Not much options.
Hopefully you can survive.
gbumaga
#7 Posted : Thursday, December 6, 2007 11:46:30 AM(UTC)
gbumaga
In case I can find a used valve, how do I get to it - from the top or bottom? Is there easy way to take off the cover?
Thanks!
#8 Posted : Thursday, December 6, 2007 11:49:29 AM(UTC)
Access to all parts is from the top. You can see it on the break down diagrams in one of my previous posts.
gbumaga
#9 Posted : Thursday, December 6, 2007 12:36:48 PM(UTC)
gbumaga
I must be asking very elementary and stupid questions since I have no experience at all with the stoves - what is holding the top down? Do I need to unscrew something or some clips holding it. I can not figure out from the diagram how to get it off.
Thanks...
#10 Posted : Thursday, December 6, 2007 12:46:15 PM(UTC)
In the middle of each burner is a part called a "venture" (#12 on the main top break down diagram). You have to remove all of them, remove burners and then the top panel.
To remove ventures could be a big problem due to rust. You can not force it very much to prevent damage to gas tubes under the top panel.
