Water won't fill in my icemaker. I have replace the icemaker, the wire harness on the icemaker, the water valve and can't think of anything else to replace except the wire harness that goes to the water valve. I have checked the water line in and there is plenty of pressure. I have taken off the plastic hose that feeds water into the icemaker to make sure it was not clogged and I have ensured that the fill tube is not frozen. Any suggestions?
Hello,
What is exact measured temperature in the freezer? It suppose to be at least 10°F for good ice maker performance.
Make sure that the shut off arm is in the on (down) position.
If the temperature is good, check for 120 VAC between the "N" & "L" test points. Make sure the test probes are 1/2" in.
If there is normal reading, then using an insulated piece of wire (14GA), short points "T" & "H" to run the motor. Leave the jumper in for a half of a revolution and remove it. The water valve should be energized in the last half of the revolution.
Post the results.
What is the complete model number of the refrigerator?
