newatappliancerepair
#1 Posted : Thursday, December 6, 2012 10:17:23 AM(UTC)
The washer is leaking from what appears to be the lower right side. It is a small amount of water, however is of concern because of the corrosion. Would this typically be the front door seal that seals the door and the tub assembly, or would this be some other internal part? Would it be possible to get a repair manual on this Electrolux Washer SN 4C84000675? That would make it easier to try and figure out which parts to order so that they are on hand when the repair is made.
-NewAtApplianceRepair. :(
#2 Posted : Friday, December 7, 2012 12:45:09 AM(UTC)
Parts for Electrolux EIFLW55HIW0 Washer - AppliancePartsPros.com
Often clicking on a parts picture will bring up a new page with more info about that part.
Without being there I cannot say what exactly is leaking.
Below is a link yo a manual.
Download EIFLW.pdf
use the gray download button.
I think that the black with white letter installs a download software on your computer that you may not want.
internal water leak (Refrigerator & Freezer Repair)
by gsmillerjr 2/28/2009 1:53:54 PM(UTC)
Internal water leak (Refrigerator & Freezer Repair)
by CVN76 9/17/2008 7:01:06 AM(UTC)
