Sorry everyone,...usual story(Maytag Neptune MDE9700AYM). My dryer drum had a crack at the weld, didnt know for a long time, found out by snags in clothes. Anyways, i replaced the drum and the entire inside was covered in 2 to 3 inches of lint. Completely cleaned out looked brand new on the inside. A few days later the heating element went out. I replaced the element along with the high limit thermostat and the thermostat on the element housing. The blower thermostat has continuity and the thermistor looks to be correct around 10,000. When i go into the diagnostic code i get 02. I reset via the panel and everything works but no heat.
Any suggestions...
Groups: Expert
The 2 in diagnostics is "open thermistor". Check the thermistor again at the control between the red and blue wire 10K ohms @ room temperature. If it checks good. With the dryer running on timed dry high heat, check for 120 VAC between the black wire on Relay#2 Heater and the white wire or N. Then check for 120 VAC between the blue wire on the same relay and the white wire.
Thanks Rick. Really appreciate you taking the time to respond! I am getting intermittent readings from the Thermistor over different times checking. I ordered a new one and hope to get it today. I will give an update when done.
Groups: Expert
Originally Posted by: rickgburton  OK, sounds good Thanks Rick, replaced the thermistor(double checked 12400). Still no heat. Checked the voltage and got an unusual range. I unplugged from wall moved it to make more room plugged it back in and got 120/120/240. Noticed the plug has play in the socket.
Groups: Expert
Access the control board. Finish the steps in post #2 after, check the thermistor.
Originally Posted by: deyqjcx  CFR Cluj beat Manchester United but miss out on Champions League last 16 kevin durant 5 As the opening 45 minutes drew to a close, United really should have got their noses in front, but Wayne Rooney saw a clever chip beaten away by Felgueiras and Chris Smalling somehow nodded wide of a gaping target from three yards out - before Cleverley was forced off with an untimely knock. The first half offered little for those in attendance to get excited about, with defensive errors offering up the only real opportunities of note. The Turkish outfit were, however, to turn their tie on its head, making events in the final 10 minutes at Old Trafford irrelevant - with United prepared to turn their attention towards more important challenges to come and Cluj left to contemplate the consolation prize of a place in the Europa League. With there nothing riding on the game for the hosts there were a number of empty seats to be seen inside the Theatre of Dreams, with one of them in the dugout - with Ferguson opting to enjoy the company of his chief executive David Gill in the stands rather than take his usual place on the bench. Dwyane Wade Shoes Blake Griffin Shoes aefzewfdfty5re What the heck?
