mickaly
#1 Posted : Wednesday, December 5, 2012 4:58:22 PM(UTC)
mickaly
I've recently attempted to trouble shoot my refrigerator that won't defrost. After detaching the back panel of the freezer I have found unbelievable amounts of ice even after 24 hours without power. Turns out that the defrost heater was smashed to pieces due to ice pressure. I have found the part online WR51X365 and it appears to be way more expensive than other similar defrost heaters. My question is do I have to use this exact part or is there another defrost heater that would suffice? Thank you.
abadfish66
#2 Posted : Wednesday, December 5, 2012 10:11:10 PM(UTC)
abadfish66
There are no generic ones you can use for this fridge. I also recommend you replace the defrost thermostat as that may have been the reason it froze up on ya...WR50X122
mickaly
#3 Posted : Sunday, December 9, 2012 10:33:21 AM(UTC)
mickaly
thanks for your info
Preachersson
#4 Posted : Sunday, July 3, 2016 9:26:53 PM(UTC)
Preachersson
My freezer iced up, took the back plate off,completely frozen up with ice,, unplugged it overnight, put back together, cooled to zero, now 20 degrees ,,,,please advise,,,,
karenhaire
#5 Posted : Monday, July 4, 2016 9:35:59 PM(UTC)
karenhaire
It seems that your compressor is having some problem. I suggest you to consult a technician for it.
