AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Whirlpool dryer motor pulley replacement question
On our Whirlpool electric dryer the plastic pulley "guard" that sits on the shaft of the dryer motor melted and wonder what it does and how to replace it as it seems to be part of the Pulley-Mtr Part Number: AP4510074 Have replaced the belt after it broke last month and it worked for four loads then the belt broke again. Didn't notice the melted plastic part as it had come off from whether it was and over to the right rear of the chassis. any help would be appreciated.
Also we have the older all metal idler pulley is the new one with the plastic wheel a better option.
thanks herrbutzie
Groups: APP Team
Hi. Best if you will replace the "guard" on the motor shaft. Unfortunately it does come with the motor pulley.Also the "classic" idler pulley is better in my opinion Part number: 691366
Make sure that you are installing the belt correctly Part number: 341241
Use the video clip for instructions. Simon.
Dryer Repair
