dp2763
#1 Posted : Monday, December 3, 2012 12:43:28 PM(UTC)
dp2763
I have a GE XL44 Gas Oven, model# Jgbc17ger4wg.
Range top works fine. Oven will not get to temperature. I have confirmed that the ignitor is fine. It drew 3.2 amps and dropped to 2.8 amps and kept glowing. I even changed it out to be sure.
The flame lit on the burner, but what i noticed is the blue flames were only 1/4" long and did not spread on the deflector shield.
What could be the problem.....valve, regulator or T-stat? How do I test these components to be sure?
Simon / APP Team
#2 Posted : Monday, December 3, 2012 2:58:28 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Try to adjust the orifice on the top of the gas valve #214 on the diagram (Turn it CCW 1/2 turn) and also adjust the air/gas mixture #217 on the diagram
Burner Assembly parts for GE JGBC17GER4 - AppliancePartsPros.com
If that doesn't help and you already replaced the igniter then most likely it's bad safety gas valve.
Post the results.
Simon.
