jthom87
#1 Posted : Sunday, December 2, 2012 6:56:51 PM(UTC)
jthom87
The lights on the front panel are out and there is no response from anything pushed. I have read elsewhere that this means i need a new motherboard. Under the freezer side up front there is a four wire connector that is disconnected. What does this connector go to and could this be my problem?
abadfish66
#2 Posted : Sunday, December 2, 2012 11:56:49 PM(UTC)
abadfish66
That connector supplies power to you blank board and water/ice dispenser
jthom87
#3 Posted : Monday, December 3, 2012 8:00:35 AM(UTC)
jthom87
it looks as if this connector is just a splice from the motherboard, or should this be plugged into something.
