i HAVE A 2 YEAR OLD LG DRYER FRONT LOADER. THE STAINLESS STEEL WELD HAS BROKEN WHICH I understand is a common problem on these. I have continued to use it and listening to the thump thump!! everytime when it goes around with every revolution. It has now stopped all together and has locked up. You can turn on, will not turn even by hand and the it will hum and then cut off. Maybe a broken belt or guide has jammed it?? I have to take a prt this weekend and see what other parts I will need but was wondering if anyone had any suggestions what it may be?? Thanks, Ray
Groups: APP Team
Check the owners manual for the drum warranty.
Simon.
