My fridge is still cold and the freezer is still cold (the coils in the back are frosty) but the fan is not running, I have it cranked to full cold, and it's not nearly as cold as it should be. I am trying to find the part that I would need to repair the fridge myself. And maybe a few instructions on how to do it. Any help would be great.
Here are your parts Parts for GE GTS16GBRFRWW Refrigerator - AppliancePartsPros.comOdds are that the fan (item 610 in the Cabinet Parts section) is toast. You can confirm this by measuring the voltage across the fan. If it is 120 volts and the fan does not turn, it is toast. The parts breakdown should help you get to it. |
THIS FORUM IS DEAD!!!!!!! |
Thank you. Ill take it out and see if they have replacement Motors for the fan locally. :) it's the only part that doesn't appear to work. The compressor and back fan work. And it still kicks on its just 5 degrees celius in the fridge.
