ppritchard
#1 Posted : Tuesday, November 27, 2012 10:30:43 AM(UTC)
ppritchard
Just replaced a door switch and Now I'm not sure if I have the wiring right?
Can't find a wiring diagram to show me the colors.
Switch tested bad, so I'm hoping that was it.
No lights and no response from any buttons.
Just need to know which wires go where 4 on switches and 2 from outer door to inner door.
Thanks for any help
ppritchard@cfl.rr.com
ppritchard
#2 Posted : Tuesday, November 27, 2012 10:48:40 AM(UTC)
ppritchard
I found the wiring diagram, But I don't know what I'm looking at.
Just need to know what goes where.
Any help would be appreciated
#3 Posted : Tuesday, November 27, 2012 11:27:22 AM(UTC)
Is the wiring diagram you have the same as the attachment?
If yes.
Then one switch gets a Tan and a BlacK.
The other switch gets a White and a White-Violet (may be just another White).
It does not matter which connectors on the switch as long as they are 2 prong switches.
I do not know what you ean by inner and outer door wires.
File Attachment(s):
15962990.pdf (484kb) downloaded 44 time(s).
ppritchard
#4 Posted : Tuesday, November 27, 2012 11:34:18 AM(UTC)
ppritchard
OK - so no polarity issues with which of the wires goes on either side of the switch?
There are 2 wires that go from the wiring harness area of the outer door to a connector on the inside side of the door. Not sure what they are for.
thanks
#5 Posted : Tuesday, November 27, 2012 12:00:47 PM(UTC)
[COLOR="Blue"]OK - so no polarity issues with which of the wires goes on either side of the switch?[/COLOR]
No. You do not have to worry about polarity in an AC circuit.
[COLOR="Blue"]
There are 2 wires that go from the wiring harness area of the outer door to a connector on the inside side of the door. Not sure what they are for.[/COLOR]
What color are they?
