hd4unm
#1 Posted : Tuesday, November 27, 2012 7:35:06 AM(UTC)
hd4unm
Fridge will not run. Only the light is on. This unit sat unused for a few years. When I plugged it in it ran for a few seconds (3-5) then quit.
I read an old post elsewhere that described bypassing the cold control thermostat. I tried that, nothing happens. I do hear the mechanical motor of what I think is the defrost rely near the cold control therm. I can hear it purr whether the thermostat is jumped or not.
Any advice to trouble shoot further?
#2 Posted : Tuesday, November 27, 2012 9:28:15 AM(UTC)
You seem to be missing the last digit or so in the model number.
Here are the units that come up when I search using your number.
See Matching Model Numbers panel.
If the unit has a defrost timer then you may be in a defrost cycle.
Give it half an hour to see if it comes out of defrost.
If not turn the defrost timer cam to force it out.
There is usually a hole in the control console cover to let you do this without dismantling anything.
If it now comes out of defrost, replace the timer.
hd4unm
#3 Posted : Tuesday, November 27, 2012 10:18:45 AM(UTC)
hd4unm
Thanks for the tip. After reading a bit more on this problem it was what I was thinking. I had it apart anyway and can hear the timer running so I just turned the cam.
Unit started right up. Must have been just coincidence that the timer was was ready to activate defrost as I plugged it in. Seems to run fine now.
Thanks for your help!!
Last digit was '7', it was separated from the rest and didn't notice it.
#4 Posted : Tuesday, November 27, 2012 12:32:12 PM(UTC)
You are welcome.
Does not sound like you will need any parts but here is a link to them just in case.
Parts for Whirlpool ET8WTKXKQ07 Refrigerator - AppliancePartsPros.com
If nothing else it will show you where the parts are located.
