vaughn quern
#1 Posted : Monday, November 26, 2012 9:52:02 AM(UTC)
vaughn quern
whirlpool dryer will not start. No drum light either
#2 Posted : Tuesday, November 27, 2012 1:16:18 AM(UTC)
Sounds like a power problem.
The drum light and the motor run off of the same side of the line (120 volts)
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Whirlpool Dryer will not start, have power "sensing light is on" Replaced both thermi (Dryer Repair)
by joanu 11/21/2013 6:32:09 AM(UTC)
Whirlpool dryer will not start (Dryer Repair)
by vaughn quern 11/26/2012 9:44:09 AM(UTC)
whirlpool dryer will not start (Dryer Repair)
by mikeshard 3/29/2012 8:49:17 PM(UTC)
Whirlpool dryer will not start. (Dryer Repair)
by c33341 3/11/2011 9:47:28 AM(UTC)
by Newglide 1/12/2011 6:54:14 PM(UTC)
by dafense 2/10/2010 6:13:16 PM(UTC)
by mbryans 1/7/2010 12:31:19 PM(UTC)
by rsqmedic8 7/26/2009 7:43:08 AM(UTC)
by bratsinc4 2/4/2009 6:05:06 PM(UTC)
