BanditSiix
#1 Posted : 17 years ago
BanditSiix
When I start my dryer, it runs fine except recently when I start the Dryer it tries to heat up for about a minute (I can feel the heat) but then just stops heating.
Now, (it's been a few days) I cleaned out everything thinking it just was accumulated lint and now it's not heating at all. When I start the dryer, everything runs fine but no heat at all. I did notice that every couple minutes it makes a rattling noise. I'm going to make the assumption that it is the unit trying to heat up the dryer.
What should I check first? Next?
BanditSiix
#2 Posted : 17 years ago
BanditSiix
I'm curious why no one is responding to my post?
Was I bad?
I could use some help here.
Thanks.
abbie
#3 Posted : 17 years ago
abbie
first thing to check would be the voltage to the dryer there should be 240 volts going into the dryer, there will be two fuses or breakers.Check them to see if there open.Then we will go from there.
BanditSiix
#4 Posted : 17 years ago
BanditSiix
Thanks for the tip Abbie but I can't seem to find the 240v on my GAS dryer LOL. What else should I try?
abbie
#5 Posted : 17 years ago
abbie
lol sorry about that,should of check the model # and i would have found out that..
abbie
#6 Posted : 17 years ago
abbie
check to see if there power to the burner 110 v, then check the coils to see if there open [continuity test]
BanditSiix
#7 Posted : 17 years ago
BanditSiix
It was the coils. Thanks
