spampinato
#1 Posted : Thursday, November 22, 2012 8:33:23 AM(UTC)
spampinato
This oven does not work on the convection setting. The fan doesn't come on, ever
rickgburton
#2 Posted : Saturday, November 24, 2012 2:02:55 AM(UTC)
rickgburton
Groups: Expert
I can't find any information on that model. It's probably a stuck relay on the EOC
Frigidaire 318010102 Clock/timer, Eoc - AppliancePartsPros.com
UserPostedImage
#3 Posted : Saturday, November 24, 2012 3:42:27 AM(UTC)
Parts for Frigidaire PLCF489CCF Range - AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...assomption/318045330.pdf
If both the convection fan and the convection element do not come on then odds are that it is the control board.
If the convection element works but the fan does not then it still could be the control board. But may also be a bad fan or a bad Auto Door Switch(Normally Open side not closing when the door is closed).
Unfortunately I do not know where this switch is. They just show it at the end of the listing in the Body Parts section but do not show it in the parts breakdown.
I am doing a bit of guessing that this is the switch as they do show the door switch as a separate item (12 and 12A).
To confuse things just a little more they show 12A as a Door Switch ( 2 prong - has common and normally closed) but also show a item 12 as a Switch [3 prong -has a common and a normally open and normally closed (a bit of a guess on my part)]. So they may have combined the two switches.
Perhaps rickgburton has some input on this.
Or someone who has had this problem on this unit.
Is it safe? Can I use electric oven again after POP noise and breaker tripped? (Oven Repair (including Ranges and Cooktops))
by Guest 3/2/2024 5:41:59 AM(UTC)
KitchenAid builtin electric oven (Oven Repair (including Ranges and Cooktops))
by Guest 1/10/2024 5:07:18 PM(UTC)
F2 Error Code on GE Electric Oven (Oven Repair (including Ranges and Cooktops))
by Guest 9/11/2023 6:33:44 PM(UTC)
Whirlpool Electric Oven Convect Broil (Oven Repair (including Ranges and Cooktops))
by Guest 8/12/2022 8:27:28 AM(UTC)
GE Electric Oven - Won't stay on (Oven Repair (including Ranges and Cooktops))
by tstwingirls@yahoo.com 2/23/2022 3:51:15 PM(UTC)
Frigidaire electric oven model number PLEF489CCF (Oven Repair (including Ranges and Cooktops))
by Guest 7/25/2021 4:06:10 AM(UTC)
LG LSE3092 Electric Oven (Oven Repair (including Ranges and Cooktops))
by cycle70 4/10/2021 11:11:00 AM(UTC)
GE Profile electric oven will not turn on (Oven Repair (including Ranges and Cooktops))
by toddlamp 3/31/2021 7:03:39 PM(UTC)
ge tru-temp electric oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/17/2021 4:26:18 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
ZLINE RA36 ELECTRIC OVEN (Oven Repair (including Ranges and Cooktops))
by AndyGray 1/21/2021 5:13:45 AM(UTC)
Help! GE Profile Electric Oven PT916SMSS (Oven Repair (including Ranges and Cooktops))
by Marsa 5/9/2020 8:36:48 AM(UTC)
Electric oven panel issue? (Oven Repair (including Ranges and Cooktops))
by nhreprops 11/23/2019 10:59:26 AM(UTC)
Can I use the electric oven without the broiler heating element? (Oven Repair (including Ranges and Cooktops))
by Al Thumbs 3/16/2019 10:53:19 AM(UTC)
KitchenAid Electric Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by frosini 10/1/2018 7:23:00 AM(UTC)
