n4moe
#1 Posted : 12 years ago
n4moe
My GE Select Refrigerator with top freezer has stopped both cooling and freezing. When I plug the power cord in I hear a click from the motherboard but the only thing that starts running is the fan. The compressor is not kicking in at all. I left it unplugged overnight and then plugged it in again the next morning but no change. Any advice please?
Thanks,
Scott
mrkool
#2 Posted : 12 years ago
mrkool
hey n4moe,
Did you try pulling the Klixon off the compressor and seeing if it's broken or not making contact?
n4moe
#3 Posted : 12 years ago
n4moe
Originally Posted by: mrkool Go to Quoted Post
hey n4moe,
I'm not familiar with the Klixon but I'll be happy to try it if you can help tell me what to look for please.
mrkool
#4 Posted : 12 years ago
mrkool
Ok, if you look at the compressor, where the wires go into the compressor,
pop off the plastic cover, behind it you'll find a round plastic Klixon overload.
Here's an image, if I pasted it right, if not, just do a google search for Klixon and you'll see one and probably how to test it.
[IMG]https://encrypted-tbn3.gstatic.com/images?q=tbn:ANd9GcTCt0Kspjw-a3-U_2b7eFbUmIuO4ZVNmwOL491cAggnWcYp4ngp[/IMG]
n4moe
#5 Posted : 12 years ago
n4moe
That's very helpful. I'll try it tomorrow and will let you know. Thank you!
#6 Posted : 12 years ago
Klixons are very reliable. I would suspect bad solder joints on the back of the motherboard WR55X10942
n4moe
#7 Posted : 12 years ago
n4moe
I'll inspect that at well but the unit os 10 yrs old. Wouldn't a bad solder joint on the PCB have revealed itself already? Thanks!
n4moe
#8 Posted : 12 years ago
n4moe
My hat is off to you richappy...one of the leads from a relay on the board had a bad solder joint that had been arcing and it finally opened the circuit. I've repaired the board (inspected it for other bad solders joints!) and it is running perfectly now. Thank you!
Thanks too for mrkool's advice. I appreciate you both for taking time to read my post and reply.
#9 Posted : 12 years ago
Very easy to fix the relay solder joints as the area is rather open.
anne grimm
#10 Posted : 12 years ago
anne grimm
oops not the same model. will post a new question. Don't know how to delete this
