StanF
#1 Posted : Thursday, November 15, 2012 4:13:40 PM(UTC)
StanF
Dishwasher is recieving power but the Control panel went blank:confused: ,does not start no indicators light. Also it seems the dishwasher has some water in the tub from last run. I would appreciate any help. Thank you.
#2 Posted : Friday, November 16, 2012 8:19:52 AM(UTC)
Your model number seems to be missing some digits at the end of it.
Most of the units have a thermal fuse on the control board that may have blown.
Also it is not uncommon for problems with the wire ni=uts that attach the unit to the house wiring.
FYI: you are in the wrong section of the forum. This is Oven Repair and you should have posted in the Dishwasher section.
StanF
#3 Posted : Saturday, November 17, 2012 12:22:20 AM(UTC)
StanF
I am sorry I didn't realize I posted in wrong forum, can/should we move it to correct forum? After opening control panel It seems there is no Thermal fuse in this washer. I will recheck the wiring.
#4 Posted : Saturday, November 17, 2012 2:00:51 AM(UTC)
Might as well stay in this section.
Parts for Whirlpool GU2300XTVQ2 Dishwasher - AppliancePartsPros.com
[COLOR="Red"]See the attachment for the tech sheet.
PS: It also shows a fuse
For some reason the site will not let me upload the tech sheet now. I will try again later today
[/COLOR]
Take a look at item 6 in the Control Panel Parts section.
It does show a fuse, click on it's picture for more info on it.
#5 Posted : Saturday, November 17, 2012 8:34:03 AM(UTC)
AppliancePartsPros still will not me upload the tech sheet.
Perhaps it is too large.
So I have put it on a 3rd party site, see below
Download GU2300.pdf
StanF
#6 Posted : Saturday, November 17, 2012 11:44:53 PM(UTC)
StanF
Download GU2300.pdf
Mr. Denman I really appreciate your help, I am not a technician, when I opened the control panel I didn't see anything that looked like a thermal cutoff switch. This model doesn't seem very common, there isn't much on the internet when I do a search. I will look at the Pdf sheets you offered me. Again, Thank you for your help!
StanF
#7 Posted : Sunday, November 18, 2012 12:01:53 AM(UTC)
StanF
Originally Posted by: StanF Go to Quoted Post
Mr. Denman I really appreciate your help, I am not a technician, when I opened the control panel I didn't see anything that looked like a thermal cutoff switch. This model doesn't seem very common, there isn't much on the internet when I do a search. I will look at the Pdf sheets you offered me. Also, I will check to see what parts I will need from your link. Again, Thank you for your help!
