AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Estate dryer looses flame once it hits the 40 min spot on dial
Hello,
I have an Estate dryer that is having the following symptioms. It will heat fine untill it gets to the 40 min spot or below that. Then the flame wont cycle on. The ignitor doesnt come on either. No ticking, or any other noise to indicate its trying . I have already replaced the 2 coils in front of the burner unit. The timmer dial will stick at times when you shut off the machine (open the door and not restart). New timmer? New thermostat? Thanks!
Ps. About 3 year old machine.
Dryer Repair
