VentureRider
#1 Posted : Thursday, November 15, 2012 1:02:26 PM(UTC)
VentureRider
Washer appears to complete all cycles...but doesn't agitate.
Where do I start?
fairbank56
#2 Posted : Thursday, November 15, 2012 2:09:59 PM(UTC)
fairbank56
Groups: Expert
After it stops filling with water does it make any noise? Is the motor running/humming or is it just quiet until it gets to drain/spin mode?
Eric
Simon / APP Team
#3 Posted : Thursday, November 15, 2012 2:17:02 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If the motor is running in agitation and the washer spins remove the agitator and check if the transmission shaft is rotating.
If it does - replace the agitator, if not - transmission.
If the washer only drains but no spin or agitation - check the motor coupling.
Here are the breakdown diagrams and Brake, Clutch, Gearcase, Motor and Pump parts for Whirlpool LSQ9600LW0 - AppliancePartsPros.com
Post the results.
Simon.
Kenmore Washer Not Agitating (Washer Repair)
by ditosp 8/8/2012 4:10:36 PM(UTC)
kenmore washer not agitating (Washer Repair)
by pedro matos 6/17/2011 2:05:47 PM(UTC)
