I've noticed the last couple times that I've run my dishwasher that none of the dishes appear to be getting cleaned. Additionally, several dishes in the bottom rack are ending up with a large streak of soap caked on. Finally, I put a basket in the top rack with smaller baby items, and it tends to contain some water when the dishwasher is done. It looks like the items in the basket are bone dry, so it makes me wonder if enough water is getting up there.
Groups: APP Team
Hi. Check following things: When the D/W filled up open the door and check if the water is at least 1 in above the bottom. Make sure that the wash arms are not blocked and jet openings are clean. Check if the filter is clean Part number: 154252401
Simon.
I guess I should have tried this before posing the question, but it turned out that a good thorough cleaning of all the easily removable parts fixed the issue. Thanks for your feedback.
Groups: APP Team
