boandsusan
#1 Posted : Wednesday, November 14, 2012 9:03:49 AM(UTC)
boandsusan
Please someone help. I understand to check the element etc when dryer is not working but I cant get to them....... all I keep hearing is check this check that. I know what to check and how to check. This is the first dryer that I could not get to the parts to check them.
Simon / APP Team
#2 Posted : Wednesday, November 14, 2012 11:38:40 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Depends on what parts you need to check.
To remove the top take 3 screws from the back out, slide the top an inch and lift it off.
The toe panel is held by 2 screws at the bottom of it.
The control panel is held by the screw at the left, small tabs on the top and larger tab on the right.
To remove the front panel take out the top screws and 2 at the bottom (one in each corner).
Here are the breakdown diagrams and Controls / Top Panel parts for Frigidaire GLEQ2152ES0 - AppliancePartsPros.com
Simon.
Guest (4)
