Our dishwasher stopped mid-cycle and now it appears there is no power. The breaker hasn't been tripped, and none of the buttons work at all. Am I looking at the electronic control board as the culprit, or are there other parts that could lead to the same issue?
Thanks in advance!
Originally Posted by: regpum  Our dishwasher stopped mid-cycle and now it appears there is no power. The breaker hasn't been tripped, and none of the buttons work at all. Am I looking at the electronic control board as the culprit, or are there other parts that could lead to the same issue?
Thanks in advance! ************************* Ordering a $110 part makes me queasy regardless, so I talked an old friend in to coming over and looking at my dishwasher. As it turns out, one of the wires leading to the control panel had burned through and luckily cut off power before it burned the house down. Problem solved.
