The defrost timer is in the housing at the top of the fresh food section (Item 12 in the "Controls" section.
If you look up at it you should see a hole which allows you to turn the timer cam with a screw driver. It only turns one way.
Turn it till the freezer fan, compressor and it's fan shuts off
You are now in a defrost cycle
The defrost heater should come on.
One thing to note is that the defrost thermostat must be frozen as it opens and stops power to the heater just above freezing.
If the heater comes on then the heater and thermostat are OK and the timer needs replacing.
Be carefull that you do not burn your fingers.
If it does not come on then it could still be any one of the 3 components.
Disconnect the heater and measure it with a meter. Should be 30 ohms approximately.
If OK
Unplug and check the thermostat, should be approximately 0 ohms.
See page 2-16 in the following service manual. The defrost system is the same as yours though the manual is for different units.
http://www.servicematters.com/m...ibrary/docs/16010154.pdf If OK
Then the defrost timer is shot re: it's contacts are not closing
If you do not own one I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
