We have an error code f19 on our Thermador double oven. We replaced the power relay board and are still getting the same code. Even after resetting at the breaker. Please help. We are hungry =)
The F19 code is for Power board Communication error. First check and make sure you have 240 volts coming to the oven. There is a high limit switch that you will need to check as well. It should read closed or 0 for continuity. Here is a link to the parts diagram page where the switch is located, as well as the part number for you. Hope this helps. Part number: AP2832064
I have the same problem. I replaced the power relay board and the switch with no luck. The voltage coming into the oven is good too. Any other suggestions?
Hello MarkE. You need to look for a bad wiring harness on the unit or the main power board or control board is bad. This is a communication issue between the boards on the unit.
