[FONT="Verdana"][/FONT]I moved a frig and didnt know I was suppose to keep it unplugged for 24 hrs I have since unplugged it but it was plugged up about 4 hours,what are the chances when I plug it back up that it will cool?Thanks:)
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
How was the fridge moved? Was it upright? If it was transported on its side, the refrigeration oil could flow into the high side lines. The reason why you need to give it 24 hours before turning it on is so the oil can flow back inside the compressor. If you already had it plugged in for 4 hours, it doesn't much matter what you do now.
I hope it still works.
