gschvach
#1 Posted : Sunday, November 11, 2012 9:38:52 AM(UTC)
gschvach
not getting 240 voltage to bottom bake element.Voltage good to broil element 240v. Is it a bad relay on oven clock/timer?
#2 Posted : Sunday, November 11, 2012 10:33:04 AM(UTC)
Parts for Frigidaire GLES389FSB Range - AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...assomption/318271934.pdf
If the wiring is OK then odds are that it is a control board problem.
Yes it could be the relay but may also be the electronics on the board that controls the relay.
