cassnbruce52607@aol.com
#1 Posted : Saturday, November 10, 2012 6:04:51 PM(UTC)
I stopped the dryer midcycle to check to see if the clothes were dry and when I was done taking out the dry ones I went to restart the dryer and it wouldn't restart:mad: I changed the thermal fuse thinking it was that, but it still isn't starting, please help!!!! The timer still runs I can hear it when I move it, could it be that it's just the start relay? It doesn't seem as though when I push the start button as though it's as hard to push in as usual:/ Like it has no spring behind it, like normal. My dryer is only a little over 2yrs old!!!!!!! UGH!!!!!!!
#2 Posted : Sunday, November 11, 2012 1:38:32 AM(UTC)
Parts for Estate EED4300VQ1 Dryer - AppliancePartsPros.com
It could be a power problem as the motor runs off of 120 volts (L1 to Neutral) but the timer sues 240 volts (L1 to L2). You may have lost the Neutral so I would start by making sure the power is OK.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
File Attachment(s):
EED4300.pdf (139kb) downloaded 14 time(s).
#3 Posted : Sunday, November 11, 2012 7:09:16 AM(UTC)
I reset breakers and also checked the dryer belt and the belt was fine and still the dryer is not coming on:(
#4 Posted : Sunday, November 11, 2012 10:29:43 AM(UTC)
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
#5 Posted : Sunday, November 11, 2012 1:29:59 PM(UTC)
all wires look to be in good shape, none are loose or in burned out condition.
#6 Posted : Monday, November 12, 2012 12:33:00 AM(UTC)
You will need a meter so you can check the thermostats, contacts etc. in the heater wiring circuit.
#7 Posted : Monday, November 12, 2012 8:50:12 AM(UTC)
well all parts are checking out for continuity except for our 220 line, looks like we need to replace it:( But I guess I should be glad it's not the dryer atleast:p On the bright side the 220 line is actually the landlords responsability, lol! Lets see which of us really gets stuck paying for it to be replaced, I'm sure since I need clean clothes sooner than later for my kids it'll end up being me though.
#8 Posted : Tuesday, November 13, 2012 2:00:09 AM(UTC)
I am glad you found the problem.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Guest (5)
