obxracer#3
#1 Posted : 12 years ago
obxracer#3
Fills for rinse then loud noise ( sounds like dry bearing ) then nothing...noise continues until timer go,s intospin. All other cycles work:mad:
sidfink43
#2 Posted : 12 years ago
sidfink43
This is puzzling, since the rinse agitation is just a repeat of the wash agitation using cold water. If it works for the wash agitation it should work for the rinse.
I would try changing out the timer, this part here.
Part number: AP4024934
and also operate it with the front panel off and see if you can see what is happening when it tries to agitate in the rinse cycle.
