matthewjones
#1 Posted : Saturday, April 11, 2009 10:48:25 AM(UTC)
matthewjones
This is a front loader just over a year old.
We purchased this 2/24/08 - Its about 6 weeks past warranty!
Go figure! Murphy at his best..
Our washer is not spinning clothes dry.
It appears to tumble the clothes but just not working like it should.
I've tried different cycles.
I would assume the belt is good as it is doing the tumble / aggitating.
Please suggest something - with 4 kids we use this too much on a daily basis. Down time creates large piles of laundry.
Thanks in advance.
sidfink43
#2 Posted : Saturday, April 11, 2009 1:51:40 PM(UTC)
sidfink43
Two things
1. Does it spin at all, and if so, can you tell if the spinning is slower than normal or shorter time than normal.
2. Look at your owner's manual and see if there is an easy way to clean out the pump and drain hose system. You may have an obstruction (very typical with a large family with kids). Note when you do this expect a lot of water to run all over, so be prepared.
I would contact both Frigidaire and the place you purchased the macine ASAP and explain the problem to them, including the fact that you are just out of warranty. They might honor the warranty since you are so close.
If you cannot get warranty satisfaction, post the answers to question 1 and 2 and I will try and get you a diagnosis.
sidfink43
#3 Posted : Saturday, April 11, 2009 5:11:07 PM(UTC)
sidfink43
Ok, I have looked at the Frigidaire stuff, and while they do not say anything directly about your problem that is helpful, on the parts diagrams they show a "trap" in the hose leading out of your tub to your pump. This is designed to trap debris before it gets to the pump and ruins the pump.
More importantly, it appears that there is a filter in this trap, to further protect the pump!! Since the machine works otherwise, this is most likely your problem, the water is not sufficiently draining and leaving your clother wetter than they need to be.
Let us know if you are able to get to the trap/filter and if that is the problem.
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Maytag MAV7600 will not spin a full wash load (Washer Repair)
by dfab 10/14/2022 11:13:21 AM(UTC)
Whirlpool Cabrio washer TWT8600 will not spin at the end of cycle (Washer Repair)
by ADK522JNRS 6/1/2022 5:53:35 AM(UTC)
Whirlpool LAT2500AAE Washer agitates one direction only and will not spin (Washer Repair)
by spmelick 3/21/2022 4:02:10 PM(UTC)
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
Cabrio will not spin or agitate (Washer Repair)
by Johneb06 1/19/2021 2:52:49 PM(UTC)
Kenmore Front Load Agitates, but will not spin (Washer Repair)
by krusen 1/2/2020 7:56:09 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Maytag MVWX655DW0 will not spin (Washer Repair)
by radams925 6/29/2019 9:50:29 AM(UTC)
Maytag A9200 Will Not Spin (Washer Repair)
by spirittoo 10/31/2018 1:58:04 PM(UTC)
GE no faults, will not spin on regular wash (Washer Repair)
by dekk_ks 3/28/2018 8:23:06 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
