bwholmes
#1 Posted : Tuesday, November 6, 2012 7:00:44 PM(UTC)
bwholmes
I just replaced the handle on my GE Dishwasher. The problem that I'm having now is that the outside buttons are not working. I'm not sure if something isn't tight or if the control panel is broke. The lights light up when I push down on the top of both the switch interlocks (start/delay) to get the outside to light up. What do I need to do so the outside buttons work? All help is greatly appreciated.
Thanks,
#2 Posted : Wednesday, November 7, 2012 12:42:54 PM(UTC)
Probably you did something wrong while being replacing the door handle. Make sure the door switches are properly engaged when the door is locked.
Here are the breakdown diagrams and Parts for GE GHDA480N10BB Dishwasher - AppliancePartsPros.com
bwholmes
#3 Posted : Wednesday, November 7, 2012 3:51:55 PM(UTC)
bwholmes
All connections are properly connected. I think it may have to do with the Plunger Interlock (1002) not being in place. Any idea where that goes?
Thanks,
#4 Posted : Friday, November 9, 2012 4:46:55 PM(UTC)
Hopefully the attached files will help you to instal and adjust the door handle and latch assembly properly.
