theroadrunner99
#1 Posted : Sunday, November 4, 2012 7:14:30 PM(UTC)
theroadrunner99
The booklet has 2002 on it. I did not install this oven, I purchased this home 3 years ago. I recently had the electric service to the house replaced, new electric box. The oven is the only item on a dble breaker. The box was replaced in July. Today is the first time I have used the oven since then, I baked cookies. I was just now putting the pans I keep in the oven back into it and discovered it has no power. The baking went fine. I went out to check the breaker box and the breaker was not tripped. I moved it to the right, then reset. Still no power to the oven. I am hoping that the breaker is bad. I have sent an email to the installing electrician tonight, a Sunday night. Can you suggest what else might be the cause? Thank you.
#2 Posted : Sunday, November 4, 2012 11:23:28 PM(UTC)
Parts for Whirlpool RBS245PDT16 Wall Oven - AppliancePartsPros.com
See the attachment for the wiring diagram.
I am assuming the clock/timer is totally dead.
Hopefully it will be an electrical or oven hook-up problem.
If not then odds are high that the control board (Item 3 in Control Panel Parts section) is blown.
File Attachment(s):
RBS245.pdf (374kb) downloaded 17 time(s).
theroadrunner99
#3 Posted : Monday, November 5, 2012 5:57:37 AM(UTC)
theroadrunner99
THank you for your reply.
you do not mention the new elec box so I assume you do not think it is due to a faulty breaker?
did I do something to cause this oven to lose power?
j
Originally Posted by: denman Go to Quoted Post
#4 Posted : Monday, November 5, 2012 7:40:29 AM(UTC)
[COLOR="Blue"]you do not mention the new elec box so I assume you do not think it is due to a faulty breaker?[/COLOR]
No, it could be a bad beaker.
[COLOR="Blue"]did I do something to cause this oven to lose power?[/COLOR]
I do not think so.
theroadrunner99
#5 Posted : Thursday, November 8, 2012 4:34:05 AM(UTC)
theroadrunner99
reply: the breaker is good, the power at the oven is good. Is the only other possibility Item 3 in the Control Panel Parts?
Is this hard to replace on my own?
#6 Posted : Thursday, November 8, 2012 2:19:35 PM(UTC)
Should not be too difficult.
Unfortunately I cannot fiond a manual for it.
Here is the install info, perhaps it will be useful to you along with the parts breakdown diagrams.
https://www.whirlpool.com/digita...ions%20-%20W10045010.pdf
