lgscubagirl
#1 Posted : Friday, September 21, 2012 7:40:23 AM(UTC)
lgscubagirl
I turn on the dishwasher & it makes the humming sound like it is going to start, then no to little water comes in to wash the dishes.? The repair people Bosch suggested in my area are closed on Fridays ?!? Crazy. Any suggestions on what may be wrong? Thanks for your time!
Brian Ahearn
#2 Posted : Sunday, November 4, 2012 7:16:42 AM(UTC)
Brian Ahearn
I have the same issue, was there a response to this query? If so, where is it please?
TheApplianceRepairGuys
#3 Posted : Sunday, November 4, 2012 7:52:49 PM(UTC)
There should be a flood switch on this model, remove kickplate. on the left side, if i remember right it is a yellow plastic peice that shuts off the inlet valve if there is water detected in the base of the unit. that would be the first thing to check
