I have a Whirlpool quite 2 partner and have replaced the logic board 3 months ago with same problem I have now again, pots & pans light and normal light flashing again. Reset did nothing, I believe this problem comes from the power company , I live in the country and we have momentary breaks in the power from time to time for just a millisecond then back on. I know at these two times there was that event and then it quite working. The cost of the part around $150 , can't keep this up. I have called the power company and they came out looked it over and trimmed some trees by the lines still have this problem from time to time. This power brown out has gone for the 12 years we have lived here with out problems till now. dishwasher is 3 years old, could put it on a switch but that doesn't protect it while its working! any ideas?
Originally Posted by: stew 57  I have a Whirlpool quite 2 partner and have replaced the logic board 3 months ago with same problem I have now again, pots & pans light and normal light flashing again. Reset did nothing, I believe this problem comes from the power company , I live in the country and we have momentary breaks in the power from time to time for just a millisecond then back on. I know at these two times there was that event and then it quite working. The cost of the part around $150 , can't keep this up. I have called the power company and they came out looked it over and trimmed some trees by the lines still have this problem from time to time. This power brown out has gone for the 12 years we have lived here with out problems till now. dishwasher is 3 years old, could put it on a switch but that doesn't protect it while its working! any ideas? I have a Whirlpool quite 2 partner and have replaced the logic board 3 months ago with same problem I have now, pots & pans light and normal light flashing again. Reset did nothing, I believe this problem comes from the power company , I live in the country and we have momentary breaks in the power from time to time for just a millisecond then back on. I know at these two times there was that event and then it quite working. The cost of the part around $150 , can't keep this up. I have called the power company and they came out looked it over and trimmed some trees by the lines still have this problem from time to time. This power brown out has gone for the 12 years we have lived here with out problems till now. dishwasher is 3 years old, could put it on a switch but that doesn't protect it while its working! any ideas?
