Originally Posted by: flashNdisplay ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) hi again gene. just wondering what type of adhesive i can use to attach the original overlay? high temp resistant glue? regular glue? epoxy? some type of special 2 sided tape? thanks in advance for any knowledge you share. I never did it and would not. It's not worth the money for a new overlay because of possible damage to a new control board which is much more expensive. Gene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I never did it and would not. It's not worth the money for a new overlay because of possible damage to a new control board which is much more expensive.
Gene. ok gene, did you mean " It's worth the money" for the new overlay? just double checking. i will order one & reassemble in the mean time. thanks for the advice, have a great day/night
You are welcome.
I meant that it's better to buy a new overlay then trying to attach the old one with risk to damage a new control board.
Keep us posted.
Need some help and Gene seems to be the man...
So...my stove works, but bake and broil do not. The control panel works. I can set the clock, turn on the oven and broil and set temps but it does not heat up at all. Previously I was getting an F10 alarm every once and a while. Noticed the oven was heating to significantly lower temps (i.e. preheat to 550, control panel would show it was done preheating but thermometer placed inside oven would show 350-400). Then received a F30 code and oven quit working all together.
I have tested the outlet, bake/broil elements and temp sensor probe with a multimeter and all are fine. Before I gambled and just bought a new EOC for $90 is there anything else I can check to be sure I am not wasting money on a part that isn't broken?
Regards, Bryan
Hi Bryan, Most likely the problem is a bad oven control board. Also the oven temperature sensor can be bad too. The oven temperature sensor can be tested for continuity. The normal reading suppose to be about 1100 Ohms @ room temperature. The oven control board does not need any tests. Just replace it. I would recommend to order the overlay too because it's adhered to the control board. - The control board (aka a clock/timer) Part number: 316557115
i have a double oven : the fan always goes on whenever you put either oven on and the fan is located where wires are and not in either oven: when i put top oven on it wont heat and fan doesnt go one either: i checked elements and both work :when i put bottom oven on , fan works and heats up great: i replaced the top thermostat but still didnt work: NOW ON THANKSGIVING DAY BOTTOM OVEN WENT OUT TOO AND FAN DOESNT WORK: I DO NOT HAVE A CONTROL PANEL AND SUSPECT THAT THE FAN IS THE PROBLEM NOW : COULD YOU TELL ME IF THE FAN HAS TO WORK BEFORE THE ELEMENTS HEAT BECAUSE THE FAN PROTECTS THE WIRES FROM THE HEAT: 9522XUB IS MODEL NUMBER:D
Hi Debora, Sorry to hear it. Sounds like the problem is a bad selector switch. - The selector switch Part number: 7403P172-60
Gene, You do a great job helping folks out here. I've been encouraged reading your posts. I have a FEF339FSE and the oven/broil do not heat at all. Is there a fuse or reset on these to check or what else might be the issue.
Thanks! Steve Newman
Hi Steve, Thank you for your good words. There are no any safety devices in your range. In such situation when both bake and broil do not work the problem most likely is a bad oven control board. I would recommend to order the overlay too because it's adhered to the control board. - The control board Part number: 316455400
Hi Gene - I think I already know the answer but want to double check with you.
Model FEF326FBD. Bake and Broil do not heat up at all. Stove top elements all work, and display operates as is everything is ok.
Checked the temp probe and it ohmed out ok. Continuity on both elements. Anything else to check on this model before purchasing the control board and overlay?
thanks ...Sam
