Garn
#1 Posted : Friday, November 2, 2012 6:04:23 AM(UTC)
Garn
Our water tap on left side of the unit has drastically lost its flow. We have changed out filters on a pretty consistent basis over the years, and recently put in a new one once this issue developed. Basically, if not used for a 10 minutes or more, the water will flow normally for a few seconds, and then it will drop to a slow stream.
A new filter didn't really help at all - what parts should I change out? thanks!
rickgburton
#2 Posted : Friday, November 2, 2012 11:15:46 AM(UTC)
rickgburton
Groups: Expert
Replace the water valve and that should fix it. Part# 67005154
Garn
#3 Posted : Tuesday, November 13, 2012 5:41:54 AM(UTC)
Garn
Replacing the valve didn't work - the same issue. So, I've changed the water filter, and the valve. What is the next thing it could be? thanks!
rickgburton
#4 Posted : Tuesday, November 13, 2012 8:00:17 AM(UTC)
rickgburton
Groups: Expert
Check to see if the water is freezing in the coil in the back of the crispers in the fresh food section.
Garn
#5 Posted : Tuesday, November 13, 2012 10:48:45 AM(UTC)
Garn
If that is the case, how do I stop that from happening?
Garn
#6 Posted : Tuesday, December 4, 2012 12:37:46 PM(UTC)
Garn
I have checked all of this. I removed it and filled with hot water in case coil to dispenser had some issues. The same thing happens. Full power for a few seconds, then back to slow, weak flow.
It seems that the problem has to be something to do with the water filter area, everything else has been checked. (I did buy a new filter, that didn't fix it either)
