2 Pages<12
Rstariha6
#11 Posted : 12 years ago
Rstariha6
Well i found the problem, If i flip the breaker the dryer will work on its first cycle. Than nothing. Flip the breaker again and same thing. Do i have a bad breaker or not enough power getting to the dryer?
Simon / APP Team
#12 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Does the motor runs when the dryer is not heating?
What is the voltage at the outlet?
Simon.
Rstariha6
#13 Posted : 12 years ago
Rstariha6
Yes it does and im not quite sure on how to check the voltage?
Simon / APP Team
#14 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
To check the voltage in the outlet insert the voltmeter's probes into the outlet.
Simon.
Simon / APP Team
#15 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Unplug the dryer.
Open the control panel and install jumper between BK-R on the timer.
Turn the power on.Run the dryer.
Check if that makes any difference.
Next thing plug the dryer into another outlet and run it.
Post the results.
Simon.
Dryer Ignitor Glows but no Flames (Dryer Repair)
by ken1234ken 9 years ago
Hotpoint Dryer Ignitor Does Not Glow (Dryer Repair)
by michaelb 11 years ago
dryer ignitor (Dryer Repair)
by hector10 16 years ago
2 Pages<12
