ferris75
#1 Posted : Tuesday, October 30, 2012 1:37:48 PM(UTC)
ferris75
Magic Chef Furnace - probably 1983 model in attic. When heat shut down, will not restart because pilot has gone out. Reset Pilot and works fine until heat shut down. Tired of lighting pilot. What is it?
#2 Posted : Thursday, November 1, 2012 1:55:00 AM(UTC)
I have no tech info on this unit and probably will not be able to find any even with a model number.
At the top of my list would be the thermocouple.
Remove it at the gas valve and check/clean that end.
Also look inside the valve where it connects to be sure that the connection in the valve is clean, sometimes they get a light brown or grey coating. If dirty clean it with a small piece of sandpaper or emery cloth. Be gentle.
If it looks clean, I would replace it
how do I relight my gas pilot light on my dryer (Dryer Repair)
by Guest 4/3/2023 9:51:03 AM(UTC)
Gas Water Heater pilot problem (Heating, Ventilation, and Air Conditioning (HVAC))
by andyaz 1/18/2021 11:15:48 PM(UTC)
Pilot or igniter? (Dryer Repair)
by Phineas 6/15/2018 1:38:09 PM(UTC)
Thinking about going backwards to a pilot on a used stove (Oven Repair (including Ranges and Cooktops))
by Ann from KY 1/13/2013 6:03:01 PM(UTC)
The oven won't heat up. The pilot is lit and not heating oven (Oven Repair (including Ranges and Cooktops))
by Hazelave.corp 11/21/2012 3:55:15 PM(UTC)
GE Range oven pilot (Oven Repair (including Ranges and Cooktops))
by larrymehaffey 7/12/2012 3:05:34 PM(UTC)
A.O. Smith Water Heater Pilot Light (Heating, Ventilation, and Air Conditioning (HVAC))
by iwanttofixit 3/11/2012 2:27:02 PM(UTC)
Gas Dryer Pilot but no Main (flame) (Dryer Repair)
by dinuba_dave 12/14/2011 2:43:58 PM(UTC)
Hotpoint pilot won't light (Oven Repair (including Ranges and Cooktops))
by loraxx 9/13/2011 12:57:03 PM(UTC)
rv oven pilot won't stay light (Oven Repair (including Ranges and Cooktops))
by robertsfox 6/11/2011 5:05:32 PM(UTC)
oven pilot light (Oven Repair (including Ranges and Cooktops))
by idahobob 3/29/2011 5:41:25 PM(UTC)
pilot problem (Oven Repair (including Ranges and Cooktops))
by jim t68 3/2/2011 7:15:30 AM(UTC)
gas FP pilot (Heating, Ventilation, and Air Conditioning (HVAC))
by terrence l. thomas 1/19/2011 11:29:12 AM(UTC)
Oven pilot turn off (Oven Repair (including Ranges and Cooktops))
by janitia 1/5/2011 12:57:10 PM(UTC)
Pilot light??? (Oven Repair (including Ranges and Cooktops))
by loriduncan 12/20/2010 12:02:10 PM(UTC)
