AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Kenmore dishwasher fills, starts to wash then stops
Dishwasher fills and begins to wash , but almost immediately stops and the number 2 light/2 hpur delay begins blinking. If I press any other button they will start to flash too. Is my problem in the electronic control board or the control panel. any help would be appreciated.:confused:
Most likely the problem is a bad keypad which is a part of the control panel but there is a small chance for the control board to be bad as well. Perform the "checking keypad operation" test as described in the attached tech sheet in order to determine which part is bad. If you will need the correct part number for the control panel, post the color of it. - The control board Part number: W10084142
Originally Posted by: Gene  Most likely the problem is a bad keypad which is a part of the control panel but there is a small chance for the control board to be bad as well. Perform the "checking keypad operation" test as described in the attached tech sheet in order to determine which part is bad. If you will need the correct part number for the control panel, post the color of it. - The control board Part number: W10084142
Gene. Thank you Gene your reply is greatly appreciated. I will check these out and see if I can narrow it down. Thanks again!!:) Sue
You are welcome Sue. Keep us posted.
Dishwasher Repair
