Fudog
#1 Posted : Wednesday, October 31, 2012 5:55:32 AM(UTC)
Fudog
Good Morning, We have a Samsung refrigerator that gives a very light shock from the door handles or case. The refrigerator is less than a year old. Any idea what could be going on? Thanks:confused:
#2 Posted : Wednesday, October 31, 2012 3:41:18 PM(UTC)
Are you sure it was not a static electricity shock?
What kind of floor is in the kitchen?
#3 Posted : Thursday, November 1, 2012 12:24:40 AM(UTC)
Also
Is it plugged into a properly grounded 3 prong 120 volt outlet?
Or is this an older house with only 2 wire wiring (no ground)?
Does it happen all the time?
Is it like a static electricity spark (shock) or is it an electrical tickle?
Fudog
#4 Posted : Thursday, November 1, 2012 5:44:24 AM(UTC)
Fudog
This is on an all tile kitchen floor. And the feeling is more like an electrical tickle.
#5 Posted : Thursday, November 1, 2012 7:43:52 AM(UTC)
Does it only happen when the compressor and the fans are off?
mherman346
#6 Posted : Friday, August 14, 2015 9:55:40 AM(UTC)
mherman346
Similar problem with a Kitchenaide side-by-side refrigerator with icemaker on the left side door. There can be, infrequently, a 115VAC shock if you touch the left side metal door front. I measure from 13VAC to 115VAC, randomly, with a DVM touching the black ground wire of the meter to the Ground pin in a nearby socket and touching the red meter wire to the metal front left door.
By removing the bottom front black plastic panel, I see the 2 wire connectors that go to the Icemaker system. Disconnecting both of these connectors eliminates the AC voltage and eliminates the shock. Now I know that the shock is being caused by the ice maker wiring. I have not yet pulled that apart to fix it... but at least it shows that the icemaker wiring can short out to the metal front door...
- Michael
