Spelman
#1 Posted : Monday, October 29, 2012 11:50:56 AM(UTC)
Spelman
Need instructions to remove microwave oven to access burnt-out bulb. Have already bought new bulb.
#2 Posted : Tuesday, October 30, 2012 11:23:21 AM(UTC)
The instructions are attached to the post.
Just to verify if the light bulb you have is the correct part, the following is the Part number: W10440740
Here are the breakdown diagrams and Parts for Whirlpool KEMS378GSS0 Wall Oven - AppliancePartsPros.com
File Attachment(s):
Removing the microwave.doc (1,141kb) downloaded 19 time(s).
Spelman
#3 Posted : Tuesday, October 30, 2012 1:03:19 PM(UTC)
Spelman
Thanks Gene. I believe part number (bulb for microwave over) is 4452164, which I have ordered.
Spelman
#4 Posted : Tuesday, October 30, 2012 3:44:47 PM(UTC)
Spelman,
The part number I posted, came up by the model number you provided. The part number 4452164 does not cross to W10440740, so I'm not sure if it will fit and work properly.
P.S. I found the light bulb with the part number 4452164. It's shown as the oven light bulb (#12 at the diagram). I'm afraid they might be not interchangeable.
Guest (4)
