horn
#1 Posted : Monday, October 29, 2012 7:48:38 PM(UTC)
horn
The interior lights still work and we get a few beep sounds but the oven won't heat and the front panel (clock, etc.) is out. Wondering if its a control board issue. Anyone know how to replace one?
Thanks.
~Bill
#2 Posted : Tuesday, October 30, 2012 12:59:34 PM(UTC)
Hi Bill,
Check for continuity the thermal fuse wired into the hot line ti the control board. If the fuse is fine then the control board itself is bad. Unfortunately this part is no longer available.
Here are the breakdown diagrams and Parts for Whirlpool RBD305PDQ11 Wall Oven - AppliancePartsPros.com
