nick_jaimie
#1 Posted : Monday, October 22, 2012 6:06:36 AM(UTC)
nick_jaimie
Tried unplugging it and that didn't work
Simon / APP Team
#2 Posted : Monday, October 22, 2012 9:47:05 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Does it gets warm or no heat at all?
Simon.
nick_jaimie
#3 Posted : Monday, October 22, 2012 5:50:34 PM(UTC)
nick_jaimie
No it doesn't get hot at all
nick_jaimie
#4 Posted : Monday, October 22, 2012 9:51:03 PM(UTC)
nick_jaimie
I had my model number wrong. My dryer is not gas the correct number is
11087731700
Simon / APP Team
#5 Posted : Tuesday, October 23, 2012 9:33:35 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you have the multimeter proceed with troubleshooting.
First check if there is 240VAC to the dryer (if not check the circuit breaker and outlet).
Unplug the dryer, remove the toe panel (two screws at the bottom), locate the manual - you may need it.
To check continuity remove one wire off every part you are testing.
Check continuity of the heating element (7.8-11.8 ohm), thermal cut off, hi limit thermostat.
If all of them checks OK - use the manual and run the diagnostic test.
The heater Part number: 8544771
The cut off kit Part number: 280148
Part number: 280148
Post the results.
Simon.
nick_jaimie
#6 Posted : Friday, October 26, 2012 8:47:06 AM(UTC)
nick_jaimie
It was the heater part thanks so much for all the help! Just ordered it and it should be here in 2 days unlike damn Sears that charges more and takes forever to get here unless you give them your first born!!!
Simon / APP Team
#7 Posted : Friday, October 26, 2012 12:59:44 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Guest (4)
