hawkinscollette
#1 Posted : Friday, April 10, 2009 9:42:00 AM(UTC)
hawkinscollette
top load washer wont aggitate, only goes in one direction when turned with hand. spin and rinse cycle work..any help would be great! thanks
#2 Posted : Friday, April 10, 2009 1:34:36 PM(UTC)
Originally Posted by: hawkinscollette Go to Quoted Post
...spin and rinse cycle work..
Does it agitate during the rinse cycle?
hawkinscollette
#3 Posted : Sunday, May 10, 2009 5:46:03 AM(UTC)
hawkinscollette
no it does not aggitate at all just spins
#4 Posted : Tuesday, May 12, 2009 10:56:32 AM(UTC)
Remove the front panel and the belt. Check if the transmission pulley can be moved in both directions.
Washer wont aggitate, spin, or drain. (Washer Repair)
by gdavies07 5/2/2011 11:37:07 AM(UTC)
washer wont aggitate (Washer Repair)
by amcconnell 8/29/2007 10:35:55 AM(UTC)
