kbrebs
#1 Posted : Wednesday, October 24, 2012 5:03:20 PM(UTC)
kbrebs
Hi, Our Quiet Partner 3 was flashing the green clean light. When my husband pushed the cancel, opened the door then closed it. There were no lights displaying and nothing would light up when we touched the buttons. We have reset the GFI switches along with turning off the main power to it. Waited all day and noticed with the door open we had the normal light on and clean light flashing, along with the timer (--). Since we read up on resetting it ... we did the Sani and heat dry twice (with the door open) and then closed it, waited 10 seconds and hit cancel. Dishwasher made some noises.. looked like it was running through a reset a few times. Then turned off again and now we are back to having no lights. Note: we do have water in the bottom.
Any suggestions? :) Thanks in advance!
#2 Posted : Thursday, October 25, 2012 4:05:36 PM(UTC)
Very likely there is a problem with the heating circuit. Check for continuity the heating element and the hi-limit thermostat (#30 at the diagram). If there is nothing wrong, replace the control board.
- The hi-limit thermostat Part number: 661566
