biltzracing
#1 Posted : Tuesday, October 23, 2012 4:21:21 PM(UTC)
biltzracing
My microwave it cooking fine however now when the food is done and you open the door the turn table stops but the fan continues to blow out the back vent inside the oven and will not turn off. I tried unplugging and resetting everything but that did not help. Is it still safe to use the oven? Will replacing the cooling fan fix the problem. Any suggestions? Thanks Barb
#2 Posted : Wednesday, October 24, 2012 3:12:27 PM(UTC)
Most likely the problem is a bad door switch.
The model number you posted is incomplete.
