My Kenmore Elite does not power up, no lights on dashboard. Electrician checked the circuit breaker, there is power coming from the breaker to the dish washer unit. But, does not power up. Is this unit defunct or can the mother board be replaced?
Please let me know what is going on here before I discard the unit.
Thanks.
Prakash
Groups: APP Team
Hi. Open the control panel and locate the thermal fuse attached to the control board. Check if it's open and replace it Part number: 8193762
Simon.
I replaced the thermal fuse, and still it did not power it on. Do you think I need to now replace the control board?
Groups: APP Team
Hi.
First you need to check if there is a good wires connection in the junction box located behind the toe panel on the right. Then check the door latch, door switches.
Simon.
