worrellconstruction llc
#1 Posted : Tuesday, October 23, 2012 6:33:48 PM(UTC)
washer is covered with condensation . the back wall is covered , bottom of the counter is swollen. No water is on the floor . no leak in the drain line. There also is no pressure on the door when closing tight.
#2 Posted : Wednesday, October 24, 2012 6:14:22 PM(UTC)
What is the complete model number of the dishwasher?
#3 Posted : Thursday, October 25, 2012 6:39:31 AM(UTC)
the model number for dishwasher with condensatio all over it is # SHE 44CO5UC/43
#4 Posted : Thursday, October 25, 2012 2:53:38 PM(UTC)
Did you replace the detergent disperser recently?
#5 Posted : Thursday, October 25, 2012 4:15:46 PM(UTC)
No soap dispensor change. She had the electronic board in the door replaced. Tha the only service on machine.
#6 Posted : Thursday, October 25, 2012 4:43:45 PM(UTC)
Pull the dishwasher out of the cabinet. Remove the right side panel and check the condensation tube which is attached to side of the dishwasher and coming down under the tub.
#7 Posted : Thursday, October 25, 2012 5:55:24 PM(UTC)
Is that the same as the drain line? Or is this a different line. I will check tomorrow. Thanks for info.
#8 Posted : Thursday, October 25, 2012 6:16:12 PM(UTC)
No, it has nothing to do with drain.
