2 Pages12>
gardner crocker
#1 Posted : Monday, October 22, 2012 3:55:40 PM(UTC)
gardner crocker
machine fills with water then stops and will not agitate. I can hear the timer ticking and if switched to spin, the basket spins and the water drains out. The agitator has been working on and off for about two weeks, but now won't work at all.
#2 Posted : Tuesday, October 23, 2012 1:32:51 PM(UTC)
Does the motor run when it should agitate? Does it make any noise besides the timer ticking at that time?
Here are the breakdown diagrams and Parts for Whirlpool KAWS700LQ0 Washer - AppliancePartsPros.com
gardner crocker
#3 Posted : Tuesday, October 23, 2012 3:16:17 PM(UTC)
gardner crocker
There is no noise at all. The water shuts off and the only sound is the timer ticking. The motor is not running at all.
#4 Posted : Tuesday, October 23, 2012 4:10:34 PM(UTC)
Open the control panel and check the wires connected to the timer.
If there is nothing wrong, replace the timer.
- The timer Part number: 3954848
gardner crocker
#5 Posted : Tuesday, October 23, 2012 5:13:58 PM(UTC)
gardner crocker
Thank you for your help Gene. Had a feeling that might be it.
#6 Posted : Wednesday, October 24, 2012 2:45:42 PM(UTC)
gardner crocker
#7 Posted : Saturday, October 27, 2012 4:17:40 AM(UTC)
gardner crocker
replaced the timer with a new one and still won't agitate and now the timer isn't ticking.Any other thoughts?
#8 Posted : Monday, October 29, 2012 9:25:06 PM(UTC)
Try it on all possible cycles.
gardner crocker
#9 Posted : Tuesday, October 30, 2012 4:13:08 AM(UTC)
gardner crocker
Tried all cycles and they all just fill with water and do nothing
fairbank56
#10 Posted : Tuesday, October 30, 2012 5:35:52 AM(UTC)
fairbank56
Groups: Expert
Could be bad contacts in the water level switch. After the washer stops filling and switches to agitate, turn washer off, pull wires off water level switch and place a good jumper between the tan and violet wires. Turn washer back on and see if it works.
Eric
agitator won't work (Washer Repair)
by min3lcm@yahoo.com 6/2/2009 8:46:56 AM(UTC)
Agitator won't work (Washer Repair)
by burt labasse 8/13/2008 10:07:20 AM(UTC)
2 Pages12>
